Every year, there are more and more electric cars on the road. This is because more and more people want to save money on gas and reduce their impact on the earth.
Be prepared for your new EV car and have your breaker box and plugs installed at you home. EV chargers can be put in by ESP Electrical Services in the greater Houston area.
Even though you can use a regular plug and a Level 1 charger to charge an electric car, the process is faster and easier if you have an electric vehicle charger installed at home.
Finding and using public EV chargers takes time and effort. If you can charge your car at home, you don’t have to.
A Dedicated Electric Vehicle Charger has benefits like:
The electrical needs for installing an EV charger in your home depend on the type of charger and your current electrical system. Most EV chargers for homes need a separate 240-volt outlet with at least 40 amps.
This usually needs a dedicated circuit from your electrical panel to the place where the EV charger will be installed. Also, the electrical panel might need to be updated to handle the extra electricity that the EV charger will use.
You should talk to a trained electrician at ESP Electrical Services about your specific electrical system to make sure it meets the requirements for safe and effective EV charger installation in your home.
To provide the necessary power, you will need to have an EV electrician install a circuit, and this work should only be performed by a properly trained and qualified professional EV electrician.
There are options for level one, two, and three EV chargers, and we provide the most recent and energy-efficient charging systems to meet any need.
We can assist you in exploring your options and selecting the best electric vehicle charger for your home. Our EV electricians are fully trained and equipped to provide the best quality materials, meticulous workmanship, and attention to detail for EV charger installation in Houston.
